Motor Parmeters for AB Ultra3000 Servo Drive
peng
Sep 2005
Chicago
48
I am about to load motor parameters to an AB Digital Servo drive (Ultra3000). I have the .udp file with me, but I have not loaded the file using the Ultraware software. Does any one have some procedure for this.
While connected to the drive, in the Application explorer tree on the left hand side of UltraWare:
1) Select the filename and drag it onto the on-line drive shwon above it.
It's pretty intuitive, but they don't do a very good job of explaining it.
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
261
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
147
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
347
Hello all, In my facility we have multiple 3HP 460V motors that are being controlled by VFDs which drive conveyor belts. The drives are randomly...
216
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,036
