maintpro
I know this is a little off topic but I could sure use some help in obtaining the proper motor size/torque specifications for a project that I am working on.
I am building a auger system to deliver powdered gypsum to a weigh station. My auger is 6" in diameter with a 3" pitch and is only 2' in length. The bulk density of the matherial to be conveyed is approx. 63lbs/cu.ft.
The auger system will be mounted directly to our mixer wich will have about 6000lbs of product in it feeding into the auger via an 8" diameter inlet.
I need the auger to turn at 125 rpm and would like to use a DC gearmotor to accomplish this.
How do I go about determining the following items:
1) The amount of torque that is required to turn the auger.
2) The horsepower and gear ratio of the gearmotor that is needed.
