Motor Start/Stop with Jog
bwolten
Mar 2014
Sumas Washington
I am in need of some big help. see attached files
File labeled 2 motor is a start/stop if I attached the right file..
File Labeled 2 motor Jog is how I would like the Jog button to work.
How would I edit my logic too add a Jog button to file labeled 2 Motor.. after245 edits I think it's time to bring in the big guns....
I'm using a mircologix 1200 if that helps.. this is more of a hobby for me so please go lite!!!
Brad
Is your jog going to drive the 2 motors in the same sequence as the usual start / stop bit B3:0/0 ?? Having the jog tied to the OTE in rung 2 is going to force B3:0/0 to what ever state that rung dictates (you usually don't OTE /OTL & OTU the same bit..). I think it would be simpler to drive another new jog bit with your jog button if B3:0/0 is off, and add a branch around all the XIC B3:0/0 with the new jog bit contacts...
Thank you for the Reply!!! Yes same motor sequence as start/stop bit, but only when holding the button on not sealed-in
So referring to file 2 motor_Jog
Rung 2 xic branch xic-------------------Ote Jog Bit (new Bit)
Rung 3 xic branch xic (Jog Bit)--GRT branch xio---------ote
Rung 5 xic--xio--xic branch xic (Jog Bit)-------ote
It appeared to work on the emulator so off to the real thing to make me humble again..
Thanks again
Brad
Hi Experts Can anyone share with me the Function blocks for motor start stop valve control and level monitoring
4,636
Hello guys, i would like to know if is possible keep always active the run command in a vf drive and for stopping the motor only send 0...
2,487
hello All, i have some requirements from customer that when they give us a signal then my machine motor starts and when signal goes low motor...
3,213
My controllogix PLC uses a start output and a stop output to start and stop a motor respectively. The start and stop output is a 5 sec pulse...
4,263
Hi all, I have been toying with the idea of changing the philosophy on one of our lines to make the conveyors turn off if there has been no...
27
6,278
