Motorola Bar code scanner with Siemens PLC and HMI
smakdown61
Aug 2009
NC
90
I want to be able to scan in bar codes and display them on my Siemens MP 377 panel. I'm using an s7-315 PLC. Where would I start for configuring this?
No idea about what bar code reader you have, but there are several versions (protocols, serial, dnet, ethernet etc), but once you got communnication between your plc and your bar code reader you can display that info anywhere. So the first you´ve got to do is to be sure what protocol you have and what code reader to use in order to communicate them. In my case I got an Accusort bar code reader (http://www.accusort.com) thru serial DF1 and my plc is a compact logix 1769-L32E.
Hi all, Im stuck trying to support a client with Motorola ACE.. I was able to upload all of the other sites to STS but one. Im working remotely...
121
Hello, I have an existing Motorola ACE3600. Using ACE CPU 3680. Is it possible to add an additional rack to the existing PLC? Thank you.
352
Hello there! first of all: Happy new year!! I was wondering if you can help me find out what's the meaning of a Motorola's ACE1000 CPU...
1,116
I was updating my FIU (Master?) to try and improve radio communications. But I also ended up deleting the Modbus configuration on Port 2, so my...
1,475
Hi..anyone can help how this MOSCAD heartbeat works?..thanks
1,626
