Mouse Not Autoscrolloing In Concept,rslogix Or Siemens Plc
jimdi4
Aug 2004
108
Hello,
My mouse scrolls fine on the Internet, MS word, Excell etc. but not on any of the PLC software I have.
I know its computer related because I can use the same mouse on my laptop and I can scroll thorough all of my PLC software. What I mean by scrolling is using the middle roller wheel instaed of moving that slider on the side...what a pain...
I have Win2k on both machines, SP 4 with the latest MS mouse Intelipoint software that I just installed today to see if that would help, but did not...any ideas anyone?
PS- I set the wheel button to Autoscroll in the mouse settings
thanks
Logix5000 doesn't seem to support scrolling with a wheel-mouse, at
least not any of the mice I have tried. It has made me say non-FCC approved words at the computer screen.
Step 7 Version 5.3
The scroll wheel is supported in Siemens Step 7 version 5.3 (it wasn't in version 5.2). It scrolls in the manager and the lad/stl/fbd editor. As far as I can tell, that's the best part of this upgrade.
As for RSLogix500 version 5.50 and RSLogix5 version 6.10, the scroll wheel works in the project tree and ladder editor.
I've seen this before in some PLC programming software (RS Logix 5000 or DirectSoft), I can't remember which.
It was the same symptoms, mouse scroll would work with standard windows apps but not with PLC software.
Solution was to install the "specific" driver for that mouse not the generic windows mouse driver.
May work for you, may not...
RSLogix works fine~
My office PC's optical wheel mouse works fine with RSLogix. I can scroll up-down when I activate the frame I need.
I am using RSLogix500 running on Win2k OS, with very old RAM and Processor. I believed it's only 128 Mb RAM on P-1 processor.I can also use the scroll wheel on the WindLR, as well as WAGO.
Regards
S.T
I have no problem scrolling through the ladder rungs in Logix5 or 500. I cannot in Logix5000 (on same pc). Can anyone verify that they can scroll in logix5000?
I use a Microisoft Wheel Mouse Optical and I can scroll in Logix5K V10 and V12. I'm running WinXP Pro SP1. Granted, scrolling in Logix5K can screw up then ladder display. But it does scroll.
Keith
Opps... I was mistaken.. my wheel mouse can scroll on RSLogix5K. one less zero makes a lot of difference hehehehe...
It's a Microsoft Optical Wheel Mouse. But I didn't have the problem of messing up the ladder.
Regards,
Sher Tang
Check this one out, My wheel mouse scrolls fine with RSLogix 5000 but in RSLogix 5 Ver 6.10 The ladder scrolls down when the wheel is moved down and the ladder scrolls down when the wheel is moved up, What a trip.
Wow Ive been up way to long
Hi, Does anybody know if it is possible to get the mouse position with Vijeo Designer Script? My goal is to cycle through all the panels by...
1,593
I have an older application that seems to rely on ICTMOUSE.DLL. I cannot locate this script extension using good ole google ANYWHERE! Would anyone...
1,995
I have some code that is working but only if linked to mouse button 1 and I really need it to be a button 2 or right mouse click function. The...
9,538
I can use GetCursorPos but that is based on the entire desktop not the active window. Is there a way to get the mouse in window location...
2,298
Anyone know how to change the mouse icon to something else using VBA? It looks like it can be done with VBA forms and based on the object the...
2,220
