Move a String in Step7
jon_hill987
Nov 2007
Devon
I am trying to move a string from one data block to another in ladder, overwriting a string of the same size that is already there.
I have tried using BLKMOV (SFC20) and FILL (SFC21) but can't get it to work. When The block is enabled I don't get an error but if I open up the data block that I am trying to move the string into and turn on monitoring I still see the default value.
Source String is:
DB100.0.0, SMS_WaterAmber, STRING[160],'WFD Water Level Amber'
Destination is:
DB8.56.0, Message, STRING[160], 'Testing123'
Any help you could give me with this would me much appreciated.
You cannot monitor a string in a DB.
Use a vat table and monitor a list of chars in the destination DB.
What parameters are you passing to SFC20 ?
based on my experience that only allows monitoring characters and even then it is not suitable for more than some 10-15 characters. same is with DB, you can monitor only first string (or part of it).
Thanks for the reply.
I am passing dbsource.SMS_WaterAmber into the source and dbtarget.Message into the destination.
When I hover over them the tooltip gives DB100.0.0/"dbsource".SMS_WaterAmber/access width 162 bytes
And the equivalent for the destination.
I have found the vat table (I think) but have not used it before, so I am not sure how to monitor a string with it.
Hello everyone! I'm moving string value from DB to Q area for displaying it at WinCC. I see some value is presented in DB in Variable Table...
5,663
Hi, I need to receive data via a DPDP coupler. On the other side it's simatic doing blockmove. On TIA side it's like blockmove doesn't work on...
959
Good Morning , I'm trying to move a total for a dose into a dose history. I'm able to get my totals to move just fine. I would also like to...
2,431
Hello! Sorry, my english is poor:rolleyes: Please tell me how to remove the line from the file. The library TsSistem no suitable function. Can be...
3,011
Hello, I am trying to move a data DB2.DB Type String [10] to another DB1.DB Data Type String [10] in LAD or STL. Have anybody done this? Move/...
1,828
