Move activation from dongle to pc
Abn
Nov 2019
Fl
37
Hi, I have several activation on a dongle.(Rslogix 5,500,5000,).
I would like to move the activation only for the Rslogix 5 from the dongle to a pc where i have other activations for 5000 and studio 5000.
any idea how to do it.
What style "dongle" an actual hardware piece from rockewell or a USB network stick you move from terminal to terminal? The latter would be nodelocked and you should just be able to rehost to a hard drive ID or the PCs built in network card.
The former, I couldn't tell ya. You can contact rockwell to find out. Activation questions/issues are free.
If it's a FactoryTalk HASP dongle open FTAM, then select Rehost Activation
Select the RSL5 one and then send it back to Rockwell's server.
Then open FTAM on the target computer and Get New Activation and it will guide you through the steps
The safest way is to contact tech support activations the can get you through it.
But thus begs the questions Why, you can move the dongle to any computer you need
You only need the dongle to open Logix program nd open your project
I was doing that but it gives the warning that you will need the product key when installing in another PC and I don't have that....this is an old laptop, the Rslogix 5 was installed many years ago and nobody can find the info. I was hoping there was a way to do it but it seems I will have to contact rockwell.
I tried that. I installed Rslogix 5 but when plug in the dongle it doesn't recognize it.
Maybe I'm doing something wrong.
I've never had an issue with Rockwell helping when I don't have the product key. Takes them just a minute and they provide the information over the phone and usually email it to me also.
Thanks for the help. I will contact them.
Here is my problem. I moved an activation to a laptop a month ago. Somehow it has disappeared. I don't have the masterdisk for that activation...
1,624
One of Rockwell engineer had visited our site and activated rockwell software with the help of move 32 bit activator. Now I want to move the...
4,920
Hi! I have a problem with my Rockwell software activation from a Toolkit master disk (keys for all their automation softwares). I used DriveImage...
18,856
I'm trying to move my RS500 activation to a newer laptop. I can't find the original floppy and it won't allow the move. I have a legit activation...
2,547
Hi. I have now for the first time had the pleasure of installing RS software where the activation is with the web-based Factory Talk scheme. It...
7,397
