Move data to different address(Siemens S7-300)
Eric.shen
Dec 2009
asa
Hello all,
If I wanna move a value (20) to DB200.DBW10, DB200.DBW20.....DB200.DBW200
how can I make it happen by using a ladder or STL ??
what instruction do I need to use??
I got a 100 step recipes in DB200, I need to updated the values when the MP377 (HMI) give me 4 values as below
1. Item number (1~12)
2. Step initial(1~100) and Step end (1~100)
3. Value ( this contains Int or Real, depend on which item been selected)
Thank you ~~
Here's the source code for an FC that will do the job and an example call.
Code:
FUNCTION FC 1 : VOID
TITLE =
VERSION : 0.1
VAR_INPUT
  iFillValue : INT ;
  pStartPoint : POINTER ;
  iBytesBetweenEntries : INT ;
  iNoOfEntries : INT ;
END_VAR
VAR_TEMP
  iDBNumber : INT ;
  iLoopCount : INT ;
  dwOffset : DWORD ;
END_VAR
BEGIN
NETWORK
TITLE =
      L     #iBytesBetweenEntries;
      SLD   3;
      T     #dwOffset;
      L     P##pStartPoint;
      LAR1  ;
      L     W [AR1,P#0.0];
      T     #iDBNumber;
      OPN   DB [#iDBNumber];
      L     D [AR1,P#2.0];
      LAR1  ;
      L     #iNoOfEntries;
L:    T     #iLoopCount;
      L     #iFillValue;
      T     W [AR1,P#0.0];
      L     #dwOffset;
      +AR1  ;
      L     #iLoopCount;
      LOOP  L;
      SET   ;
      SAVE  ;
END_FUNCTION
TO About L D[AR2,P#0.0]
Thank you About L D[AR2,P#0.0]
I found it very useful, and how can I make the 100 step automatic put the input value into DB200 , if I choose 1 ~ 20 step , then it will put the input value into DB200.DBD0, DB200.DBD32, DB200.DBD64......DB200.DBD640 , automaticlly
How can I do this
Best Regards,
Eric
How can I do this?? If I receive a initial step figure 10 and end step figure 20 from a HMI, how can I point these step into my DB200's step (100...
3,135
there is another problem when I use the Function below: there are 100 step in the DB200 there are 12 items for each step: Step 1------------...
4,422
RE:Another Q for Move data to different address(Siemens S7-300) Thank you again for this, However I wanna to ask about: If I receive a initial...
2,585
Thank you About L D[AR2,P#0.0] I found it very useful, and how can I make the 100 step automatic put the input value into DB200 , if I choose 1 ~...
1,851
Afternoon, I have a DB in TIA Portal V16 that is optimised. I cannot change this. There is an array inside that block which consists of 3000...
1,160
