akash11132
Hi All,
I am using 2 MOVE instructions in Studio 5000 logic designer to move 2 different values in the same destination tag N7[190]. Two momentary push buttons from HMI (Panel View Plus 800 terminal) were used to energise the XIC bits. If XIC-1 is pressed, 2 is moved into N7[190]. If XIC-2 is pressed, 4 is moved into N7[190].
Example:
Rung 1 |--]XIC-1[----MOV(Source:2 Destination:N7[190])---|
Rung 2 |--]XIC-2[----MOV(Source:4 Destination:N7[190])---|
I can the see the bits energised(green) when the respective XICs are pressed. But, I am not able to see the changes in the value of N7[190]when the XIC-1 or 2 are pressed. I have attached the screenshot here. Thanks in advance.
Regards,
Akash
Example:
Regards,
Akash
