Moving Activation to A:/ drive
kevgoods2
Guest
K
I am running Windows XP. The "move activation" utility doesnt work. How can I move my activation back to the master key disk?
Kev,
There are a couple of reasons perhaps for the error, let me explain.
First of all be sure that RSLinx is NOT running at all, either as an application or as a service. The EVMOVE/MASTER DISK routine may actually have 2 different programs, one that is based on 16 bit and the other is based on 32 bit. You may try the other utility. The serial numbers on the activation file must match the serial number on the "Master" disk, if they don't you will encounter a problem. If the "Master" has it's write protect window set for protection, that could be a problem. Also, there is a problem with USB floppy drives and the XP system, there is a patch available. I had problems moving activations until I found the patch. I don't remember the patch number but I'm pretty sure I got it from MS.
Lastly be sure to have administrator rights, you may need to log onto the computer with admin rights.
Good Luck!
Bitmore
Hello Everyone, I just moved my license EVSRI.sys to my network drive using emovecf.exe. When I move it back again to my c drive it shows...
2,786
We bought RSLogix 500, RSLogix 5000, and FT View Studio (all were the download versions) a couple of months ago, and have the activation files on...
19
24,916
One of Rockwell engineer had visited our site and activated rockwell software with the help of move 32 bit activator. Now I want to move the...
4,920
I'm a Siemens person, and this is one of my first AB programs. The customer wants everything programmed in Ladder. I have a lot of data (3...
228
Hello, I have a compact Logix plc and I have been task with configuring alarms into our SCADA when an Analog signal stops moving. The analog...
249
