MP270B ethernet trouble
wanrover
Jan 2005
JP54rl
17
I posted this over at siemens support forum.
I ’m building three identical machines. These machines are each set up with Multi Panel MP270B Touch-10 TFT (6AV6 545-0AG10-0AX0) , CPU 315-2 PN/DP (6ES7 315-2EG10-0AB0 / V2.3) and a Scalance X005 ethernet switch. The X005 switches is connected to a higher level Scalance X-208 switch.
The problem is that only one of the multipanels is willing to talk through its X005 switch, the other two panels refuse. If I connect them to their switch, both lights on the ethernet interface lights up and stay on. If I exchanges on of the non working switches with the working one the problem don’t move, if I exchanges one of the non working panels with the working one the problem moves. So I think the problem lies in the panels. If I connect
the non working panels directly to my lab-top I can communicate with them through the Ethernet interface, so the interface have to be in order.
Serial numbers on the panels is:
C-TDF10017 working
C-TDF09977 not working
C-TDF10007 not working
Best regards
Geir
Have you set different IP addresses ?
Are the IP adresses in the same subnet ?
I.e. 192.068.0.3 ... 192.068.0.4 ... 192.068.0.5 etc.
Is everything integrated into one STEP7 project ?
If you have an integrated project in STEP7 with the PLC and all 3 panels then STEP7 will take care that no simple errors are made in the configuration.
Hi Jesper.
Yes all panels are on the same subnet and have different ip's.
And yes everything is integrated in one step 7 project.
Just tried to connect the non working panels directly to the X-208 switch and then they work fine. So the problem must lie in some sort of incompatibility between these panels and the X005 switch.
Hello. I have a problem with a MP270B, I cant communicate via IF2 RS232 port. I have made an OS update via the MPI port, but still having problems...
3,751
Hi I am trying to setup a PROFIBUS DP connection between a Siemens S7-314C-2DP plc and a Siemens Multipanel MP270B. The PLC and touch panel are...
10,493
Hi, I have created a diagnostic screen which comprises of a jig JPEG ,Alarm view,twelve buttons and six symbolic I/O fields running textlists...
1,966
Hi, I need to switch two MP270B Protool projects over to WinCC Flexible. I'm going to do this late tonight and i...
4,273
Hello, My client says that the clock was changed automatically to year 2006 without anyone entering the control panel. Is this possible in some...
2,102
