MPI Communication network
bzewain
Jun 2016
Al-MinuFiyah
Hello , I've a problem with my graduation project ( Sorting system by height ).
I'm using Simatic Step 7 ( Programming )+ Winn CC Flexible ( HMI ).
The problem is that after transfering our HMI Project to ( SIMATIC Panels series 170 ) Via ( Ethernet ) I tried a simple PLC Program to check that HMI is functionally good , but the screen ( with our HMI Details already on it ) doesn't respond to our input ( I124.0 > M0.0 ) , After using WinCC Flexible Simulation the simulation worked correctly !
So , I think the problem related to our MPI Connection.
Detailed Info .
1- PLC Connected to Laptop Via MPI ( Simatic S7 used ).
2- Screen Connected to Laptop Via Ethernet ( WinCC Flexible used ).
3- Screen Connected to PLC using Profibus Cable ( Directly after it was connected through Semiens motor drive ).
As we only have 15 days to fix all our problems to end our project , I hope anyone help me with this .
The panel is connected to the PLC via Profibus or MPI?
It is not clear in your post.
How did you configure the connection in WinCCFlex? Profibus or MPI?
Hello Mike, Thanks for you reply.
PLC > Screen #Profibus
PC > PLC ( S7-300 ) #MPI
___________
PC > Screen #Profinet (used to transfer , As our MPI Cable to PLC Didn't help )
We tried to transfer HMI ( Using WinCC ) Via (PLC MPI ) To (Screen Profibus) but it didn't work.
I hope It's clear now .
OK,
have you configured the Profibus port on the Panel? It has to be configured on the panel.
This is done from the control panel on the unit.
Hello Mike ,
Sorry for that mistake ,
The connection between ( PLC and Screen ) > MPI
After we Selected Profibus/MPI connection , we tried to transfer our HMI but error message appeared " connection broken " .
That's why I'm asking about MPI Connection with Profinet ( The only way succeded to transfer our HMI Programming )
Lets make it easier -
What CPU are you using ? Catalog number ?
What HMI are you using ? Catalog number ?
On one post you indicate you are using MPI, another Profibus, and now you mention Profinet (Ethernet)!
Tell us the catalog numbers, so we can determine what is possible.
No matter what you want to use, you have to configure the port HMI, this is not done in WinCCflex. Have you done it?
Quote " you have to configure the port HMI, this is not done in WinCCflex. Have you done it? "
I've used PG/PC interface to select HMI adapter , Is that what you mean ?
Yes Mike , That's right .
The only way that the transfer correctly done is by ( Eathernet ).
We've tried to use MPI Cable but we can't configue it , We've done what's illustrated in the manual but it doesn't succeed to transfer the HMI .
Sorry for all this , we're the first group to do this and our supervisor doesn't have enough experience in this .
Hi All I want communicate PLC S7 300 by pycharm and use Libnodave pass usb mpi Can do it? If can please guide me (exemple of script python) Thank...
1,959
Dear friends . I have is CP5711 siemens , it is having USB cable from Laptop to CP5711 Port. but does not have a cable from Other side (serial)...
4,385
I designed 6 pieces S7-300 Plcs and MP277 HMIs.They are contolling different process and they are communicated by mpi.All of hmi have got the...
4,160
Hii!! I am trying to communicate S7300 CPU314C. The CPU is already attached to PROFACE IPC. I want some device which can convert a single MPI to 2...
1,805
Hi, I have a arrangment of 13nos TP177A HMI , 13 Nos S7-313C CPU's & WINCC 6.2 on MPI network, My problem is wincc communication is break for few...
4,689
