Siemens MPI communication
techparag
Nov 2011
4, amar industrial estate, bhopar nandivili road,
Hii!!
I am trying to communicate S7300 CPU314C. The CPU is already attached to PROFACE IPC. I want some device which can convert a single MPI to 2 serial ports, so that one Serial port can be given to PROFACE HMI and other is available to me to communicate with another SCADA.
So, I am trying 2 Masters to communicate with the same PLC, so that workers need not access the same PROFACE IPC that is very close to process/ manufactring machine.(please know if thats possible??)
Please suggest.
Regards.
Grateful for your reply.
Now, the siemens PLC is connected to MPI to serial converter. This serial goes to the HMI that runs SCADA. I want to take the same PLC to another network through ethernet. Is it possible to split the two wires of MPI and connect it to two MPI to serial converters and then PUT one serial with exisiting HMI and other to a converter that will again convert the serial to MPI?
Please reply.
Regards,
Parag
I may be wrong but I believe some of the Proface HMI's can be used as cross platform devices.
You should be able to seamlessly connect using your HMI -
I have not done this.
Hello everyone, I have S7-300 PLC connected to HMI pannel with Profibus. I bought a USB/MPI+ cable from ebay, now this cable does not support...
4,983
Hi masters, I have some issues in MPI communication between Proface HMI and S7-300. I'm using a MPI adapter which is same like SSW, one side is...
6,599
good morning, we have Siemens HMI MPI 377 19 inch, the screen is Black but its working, and we don't have backup. i have new screen, my...
3,888
Hi all, Before the computer decided to update windows 10 last night my cable was working fine.....now its not. Does anyone have the drivers...
2,488
  • Poll
I am beginner for PLC programming and I have cable s7 300 USB/MPI cable but unable to find drivers for that cable . Can any one help me to find...
3,085
