Siemens USB/MPI+ and Profibus communication
zer0net
Jul 2011
canada
24
Hello everyone,
I have S7-300 PLC connected to HMI pannel with Profibus. I bought a USB/MPI+ cable from ebay, now this cable does not support profibus, so i can not just connect it to profibus cable at my HMI pannel I have to go all the way to PLC unplug the profibus connector and then directly connect the USB/MPI+ cable. Is there a work around or a modification that i can do to the USB/MPI+ cable to make it work with profibus?
your help is greatly appreciated.
Thank you
definitely not genuine, its a clone, but it is using the same drivers though.
Hardware version 1.0 and Firmware version 1.2
I've never used any chinese interface, but all the german clone interfaces match functionality 100% so support Profibus and can be externally powered so you can plug into the network anywhere.
Looks like your Interface is MPI only.
I guess it is, can you recommend any german clones? basically i'm looking for something cheaper than the original, dont feel like spending $500 on the cable.
but it must have something to do with getting power, i'm not familiar with how the MPI cable is wired but I know that the profibus is only 2 wires and i dont think they provide power to the cable.
I use an IBH netlink - Ethernet to MPI/Profibus on non PN Cpu's
http://www.ibhsoftec-sps.de/english/Selection_Hardware_S7.htm
Prior to that i have used USB/Serial interfaces from
Systeme Helmholz,process-informatik & MHJ which i think are all basically the same.
I think its more likely the interface board - the adaptors i've mentioned all support MPI/Profibus but don't use the Bus cable you mentioned.
Geniusintraining a member here sells the interface i think you have, so would be able to better advise.
Website: http://www.plctrainer.net/PLCProgrammingCables.htm
Have you tried it in the CPU DP port with PC adaptor interface in set PG/PC interface set to Auto?
Yes I have, It works fine when directly connected to PLC just doesnt work if i connect it to the profibus at the HMI end or profibus connector connected to PLC (the profibus connectors I have are dual port, one end you can connect to something and you can connect something else behind it)
Right - bottom line you need either an aftermarket adaptor with external voltage capability or siemens wise CP5511/12 pcmcia or CP5711.
At a node or HMI you simply have no power for your adaptor.
Hi all, Before the computer decided to update windows 10 last night my cable was working fine.....now its not. Does anyone have the drivers...
2,488
  • Poll
I am beginner for PLC programming and I have cable s7 300 USB/MPI cable but unable to find drivers for that cable . Can any one help me to find...
3,085
I connected s7 300 plc to pc via siemens mpi usb adapter.I used simentic manager and view the data.It is working with simetic manager.But i can...
3,033
Hello everyone, A few months ago we purchased the MPI-USB adapter Siemens cable, which came with an USB to MPI module cable, the MPI module, and...
7,793
Anyone have a driver for XP for the MPI USB Converter for connecting aPC to a Siemens PLC thanks
2,691
