MS Surface and RSLogix
Christoff84
Jun 2006
Cambridge, ON
407
Has anyone tried using a MS Surface tablet with Windows 7/8 to run RSLogix 500 or 5k? Seems like a nice alternative for simple field troubleshooting where you have wireless access available.
You could probably get it to run on the pro version, I doubt it would run on rt.I may be wrong though.
I can't answer the question, but I know that it won't run on an RT Version. RT can't install desktop apps.
I have a Surface Pro 2 and haven't found anything that won't install and run on it so I suspect that this will be simply a matter of answering this question:
"Will the software (RSLogix etc.) run on Windows 8.1 Pro?"
If so, then it should work on a Surface Pro 2.
Hello, I have been shopping around for a while, seems like alot of them will only inspect a small area. What I want to do is inspect a loading...
1,886
I'm curious if anyone has used a Surface Pro with Wonderware? I developed the application in 1920 x 1080 and that is the resolution for the main...
1,551
If you didn't see Microsoft's press event they released the Surface Pro 4 but also a full laptop dubbed the 'Surface Book'. Looks like it could be...
3,021
This isn't a question but more of a Answer for many people who I know have been thinking about this. We have a Surface Pro that I have got running...
2,257
Hi all, I am rebuilding a circa 1970's twin surface winder for light gauge plastic film. The old motors were of the eddy current variety. I have...
3,103
