MSG commands slc/5/05
mp2admin
Aug 2007
pa
Hi, I am new here and trying to read all the posts related to msg commands but am still in a bind to understand them. I am trying to read data from an ether net IP # and when the ip is not accessible the msg commands errors out. I am testing everything by using a timer to toggle the msg command but after awhile the msg command does not work and the waiting for que space is checked with a "1". I have tried all of the suggestion but am stumped to get one msg command to work let alone cascade multiple msg commands. Could someone lend me their knowledge.
Your post is very confusing. Could you list it out in detail.
Something like:
I am trying to send a MSG from a 5/05 plc with IP Address. XXX. XXX.XXX.254
to a plc-5 with address XXX. XXX.XXX.253
Here is a screen shot of my msg setup dialog box:
109
I have an 1769-L16ER that I use to test code and I just found that I can't create MSG tags at the local program scope - they have to be done at...
199
I have a client who periodically experiences network communication issues. Sometimes when I VPN into the site, their SCADA systems will flash comm...
193
I'm trying to read/write to an SLC5 with a ControlLogix L71 V35 plc that fails. The exact same code works on an L82S with V32. Is there a known...
302
Hello all, I am currently trying to establish a message instruction to pass data from a 1756-L73 to a 1756-L71. My communication path from the...
373
