MSG instruction in RsLogix 500 Error
Adam303
Aug 2009
Chicago
587
I have a set up where I’m using a SLC 5/05 communicating via Ethernet to a 22-comm-e which is housed in a Power flex 40. The first MSG instruction writes to the com integer address N41:3 time out of 5 sec. But I get an error that (hex) e6. I’m not sure what it means since the error is not explained in the Help file for the MSG instruction in RsLogix. See attachment. Can Any one explain what would cause this error?
Firstly we need to send a time-out value to the drive (in seconds), before sending any control data. The N42:3 value normally defaults to 0, and so needs a non 0 value before it accepts any valid control data.
LOUD AND CLEAR!!!!
Ken I don't know how I have missed that I have like 3 copies of the RA technote you just posted. This just makes me so mad. Anyways thanks for the help. I’ll be getting off work in about an hour and I’ll be sure to change that and see how this works of. I’ll post back tomorrow.
Thanks again.
Hi All, this forum has been of a great help for me in learning. i have two problems 1- I have setup an alarm so i want to calculate the number...
2,977
Hi All, I am new to plc programming. I have created a ladder logic in rslogix 500. Now I want to give input at one plc and get the output on the...
11,113
Hey all, I’m looking to set up a client/server Ethernet connection with a device to communicate to my Schneider plc. I’ve done this before with AB...
2,697
This tripped me up yesterday, thought I'd share the results of a conference call with RA this morning: There is a change between version 10 and...
3,165
I am new to using the rslogix 500 msg instruction, I am getting problems setting it up. I have two a slc 5/03,s connected to ethernet via 1761-...
13,164
