Unity pro equivalent to rslogix's MSG instruction
MrL1234
Nov 2016
London
Hey all, I’m looking to set up a client/server Ethernet connection with a device to communicate to my Schneider plc. I’ve done this before with AB PLC’s using the MSG instruction, does anyone know how I would do this in the unity software?
Depends on platform:
Try mstr block for quantum and read_'var and family for M340 and premium. You may need a send_request block too, depending.
Have a look at these to get started. If you can be more specific it would help. Platform? Ethernet module? Protocol to use?
I’ve had to start teaching myself how to use Unity Pro (for among other things messaging) and the most helpful approach so far was to forget what I knew/know about using RSLogix.
What are you trying to connect to and between?
The Ethernet I/O will communicate via ModBus TCP pretty easily.
If you want to read or write to another PLC over TCP then you setup the remote I/O to send and receive data over memory addresses and the reads and writes are pretty much handled automatically.
Can anyone tell me what the equivalent of a oneshot instruction in unity pro is? Many thanks
2,377
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
179
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
404
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
716
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,929
