MTS Position Sensor
I've been tasked with adding a 3-wire pressure differential transmitter to a system and drawing up the wiring to an existing PLC board. The...
787
I have 2 different MTS Temposonics R-Series position sensors being used in a program. Each MTS is tracking a single axis on separate machines...
2,765
I am working with an absolute mts encoder through ethernet connection, connected to a contrologix 5000, but after a few instances the reading is...
1,224
Dearest Colleagues, Task is to communicate on two levels. First level is to collect data in PLC from some flow meters and handle them, and second...
2,134
Mts
I have a temposonics transducer where the Red LED is flashing. Missing (external) interrogation Do you know what that means?
2,926
