Multiple 480 contactors in one enclosure
PeeEeLSee
Feb 2024
Midwest
Hello all,
I have a question and would like a few opinions if possible. 5x 480 outlets control 5 machine. I want to run them through a contactor each and having PLC control when its able to have power. Any big safety concern in shoving all 5 contactors in a quite medium-large sized enclosure? Will be having 5 line going into the box from these 5 outlets and 5 load back out of the enclosure and into the machines.
Thanks again.
Should be no issue....contactors are electromechanical devices, so no real concern about heat dissipation of electronics. Try to keep wire entry and exit space above and below contractors reasonable for maintenance purposes, but other than that, should be fine.
is it possible to install multiple ibaPDAs on single VM or PC?
29
Hi. I need to create several alarm servers in an application, but first I need to know if there is any impact on communication, or if more...
64
129
Hi, Is Control Expert V15.0 supposed to support multiple monitors? I'm running Control Expert V15.0 on my host Windows 11 PC, connected to two...
72
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
188
