Multiple AB PLCs in 1 Studio 5000 project
huzzygr8
Oct 2020
Germany
Hello everyone,
I was wondering if one could program more than one AB PLCs in a single Studio 5000 project. I have programmed machines with more than one PLCs in TIA portal and was thinking if it is also possible in Studio 5000?
If yes, where can I find the option to add another PLC in the project and program it independently from the other PLC?
Regards
Huzefa
No. Think of a Studio 5000 project as a single controller and all the logic, data, documentation, and configuration for that single controller. Of course, that is today in 2020. That may change someday.
OG
You can have multiple Controllers listed, however only one can have the program and be the program Controller, the others will have their own programs. It'll be how you transfer data between them, as the Produce/Consume tags will not become available until a second processor is added UNDER the ethernet tree.
Multiple PLCs in our plant communicate using either MSG instructions or Produce/Consume. Is there an industry best practice for documenting this...
782
Hello Friends; We have 10 NOS. the machines which were designed in RSLOGIX 5000 and the control system is TT4000 by SOLAR TURBINE. I want to...
3,867
Hi, I would like some help in figuring out (1) how to monitor communications between a PanelView and multiple PLCs, and (2) what to do, if a PLC...
2,199
Hello, new member to this site. My current job requires troubleshooting on 20 different plc's. We also have to use our own laptops so there is no...
2,898
Hello everybody, I work in the field of industrial computing and sensors. However, I am not an automation specialist. My expertise is more on the...
2,137
