multiple IP addresses on one computer
realolman
Mar 2009
here
584
We have several PLCs with static ethernet conections. I have to change the IP address on my laptop to match the target PLC.
Is there a way I can make and use a list of addresses and subnets , perhaps named for the equipment, from which I can pick an address for my computer
windows 7
thank you
You can make a little batch file, this is one I use:
REM Sett Viola Nett
netsh interface ip set address name="Lokal tilkobling" static 221.200.1.147 255.255.255.0 221.200.1.19
netsh interface ip set dns name="Lokal tilkobling" static 221.200.1.12
Just write in notepad and save as .bat file
Hi guys, so I'm using BOOTP/DHCP tool in my virtual machine for setting up an IP addresses for basically everything. My only issue is always with...
370
When machine has only 1 IP, we hook up a wireless client and set a static IP. Works Fine Alot of our newer machines have multiple IPs for PLC...
6,165
I have the following situation CALL FC71 Read_in_DBno: DB100 // Input is a Block_DB I want this to turn this to something like this: (i know...
2,248
Has anyone ever tried to send email to multiple addresses with a CompactLogix. Manual examples affect sending to only one address (...
4,067
Is it possible to have two addresses that monitor the same tag on a HMI screen? For example, let's say a user inputs the number 10, is it posible...
1,840
