Good Day,
I am programming a machine using a EZautomation touch planel PLC and have run into a problem using multiple values in a timer.
I have made a screen where the user can enter 3 different values into 3 seperate buttons, but now I am unsure of how to enter those values into the timer. Do I have to use 3 seperate timers,(which to me seems wrong because all 3 would be loaded into the timer so it would just time to the longest time, correct?). I have to also do this with a pressure switch set up as well. Values can be entered into boxes and the machine with create a vacuum within a sealed chamber.
Dana
Dana
