The simplest method (assuming FTView Standalone or SE, not ME) is to make another macro that simply calls the subsidiary macros you want one at a time, and put the new 'master' macro in the startup/shutdown command box on the dialog for the display (Right click display, "Display Settings | Behavior"
That may work for you, but sadly, FTView sometimes manages to completely unload a display before the macro chain terminates (depending on what you are doing), so I typically try to put all of my startup/shutdown code in VBA and handle it there.
If you go the VBA route, you want to use the Display related system calls "Display_AnimationStart()" and "Display_BeforeAnimationStop()".
A simple example would be for trend displays, this is a simple method of retaining settings to the trend between closing and opening the window again:
Code:
Private Sub Display_AnimationStart()
Trend.LoadTemplate "LastView"
End Sub
Private Sub Display_BeforeAnimationStop()
Trend.SaveTemplate "LastView"
End Sub
