Murphy Switch
Murphy.......
The one I have seen was a "MERCURY" Contactor type switch used in a heating application. Apparently the vacuum sealed chamber with liquid mercury provided a lot longer life in a high AMP switching than your typical contactor would have......
:D
O Jonsson
The term "Murphy Switch" comes from the oil patch, and specifically refers to the line of mechanical gauges with switch contacts that were used for protection circuits for engines, compresors, generators, etc. The button on the front of the gauge was to over-ride the contact during startup, usually a low lube oil pressure shutoff or warning device. The primary manufacturer of these switch gauges is the Frank W Murphy company, but there are other manufacturers as well. In later systems there was a latching relay added, that also got called the Murphy switch, to indicate if a fault had occured, and to reset it, the button onthe front had to be pushed in.
Hope this helps. The switch gauges and relays aren't as popular as they once were, especially with small electronic controls being cheaper and actually more reliable (at least to some people).
Hi, Can anyone tell the authentication password of Murphy S1501 Mirco-Controller for Configuration?
1,571
FWMURPHY M i l l e n n i u m P r o g r a m m a b l e C o n t r o l l e r (w w w . f w m u r p h y . c om) Local and remote communications...
5,176
Hello, I have a A.B Compact logix communicating with two fanuc robots via ethernet. The plc also communicates to an automation direct hmi screen...
193
Looking for a supplier of Layer 3 Network Switches DIN RAIL MOUNT, in Alabama, In the UK we would use Typically in the UK we would use...
191
What happens if you power up a 1783-MS10T with a Compact Flash card from a 1783-MS06T? Does it work, but with the "extra" ports unconfigured? If...
77
