mV Analog inputs on Profibus/Profinet
CharlesM
Aug 2005
Arkansas
1,129
Im looking for an analog input card that will take a 0-20mV input and can be put on Profibus or Profinet. Typically I take the mV signal into a signal conditioner then into a regular input card but this time I have 10 inputs. I think I can save some money and a lot of wiring by removing the signal conditioner. I've been working with some Beckhoff cards but they are more than just analog inputs and are difficult to setup.
Any suggestions?
I am converting a SLC 500 to a Compact Logix. I plan on using a Compact Logix 5380 with conversion Kit. The problem is that the analog input cards...
150
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
108
Hello I need to message read the entire 16 channel raw analog inputs from a 1769-L33ER Compact Logic controller to another 1769-L33ER Compact...
249
I have a SLC500 5/05 and we have an alarm setup to monitor the status of the Analog Inputs we have wired to a 1746-NI8. We are using 5 of the...
2,817
Hi, I'm curious if anyone has made a master sheet or cheat sheet for all allen bradley card's analog inputs/outputs? As much fun as it is to...
1,589
