Need a 5vdc inductive proximity sensor
kolyur
Oct 2004
Wooster, Ohio
1,602
We have an old piece of equipment with 5vdc control power. One of the components is a 3-wire NPN shielded 12mm cylindrical inductive prox. I have verified that it is NPN and does in fact run on 5vdc. There are no markings on the sensor to identify the manufacturer. Problem is, I can't find any replacements with a supply voltage this low... everything seems to be 10-30v. I'd really like to find a drop-in replacement as we have about 3 dozen of these machines. Any suggestions?
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
187
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
342
169
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
70
Good evening. I display the step number of a SFC on a display. Sometimes, on a trip, it goes quickly through many steps and I need to prove to...
133
