Need a PanelView 550 firmware file
Sep 2010
Uruguay
Hi guys,
I've an old PanelView 550 terminal, cat No. 2711-B5A5, and I was trying to upgrade its firmware. Nowadays, it has FRN 1.07 on it.
I tried using the Firmware File Transfer Utility, located at the PanelBuilder32, but after the upgrading process starts, the PV stops it and shows an Error, code 25. I looked for this code in the PV manual and it says "Firmware not compatible with boot code", so I presume that the firmware file is too new for the terminal.
(The one that I was trying to download is version 4.41.00)
Does anyone have an older firmware file???? It'd be much appreciated!
It's called M55BDH4.EXE and it's located in the PB32 installation CD, under \PVFirmware\PV_Terminal_FW\FW_Direct\2711-x5ax\
That's correct: version 1.07 was the last firmware released for the PanelView 500 Series A terminal, about fifteen years ago.
Any terminal with 1.x firmware cannot be upgraded to anything higher than version 1.07.
I am looking for a Panelview 550 firmware file. The current firmware is 3.01 and I am looking for something in the 4.xxx or higher. I checked...
6,656
I currently have an issue trying to track down a tag in the PLC. This tag is for a panelview indicator that was custom created. Can someone assist...
1,808
Hi guys. I have another problem. This time with PanelView. I am working on project with PanelView Plus 7. It offers just upt to 200 alarms. But I...
2,558
Hi, guys, we have one production line with 5 Panelview Plus these are connecting to one Logix5000 via Ethernet. We want to change one...
2,319
Dear forum: I have FactoryTalk View Studio ME, PanelView Plus 1000, and Windows CE On the PanelView I am using the: Program Launcher & Foxit...
5,203
