Need advice from seasoned Siemens programmers... Please.
Dec 2010
Toronto
Hello,
I just got a job as a Junior PLC programmer. This company uses only Siemens. At first I was sent to a US facility where I set up a test bench using (1) CPU 315-2DP and (2) Wago 750 Input and output Profibus Modules (343, 600, 430, 530, 602). I was able to pick up S7 fast as I have some PLC experience. However, my knowledge of programming is not enough to contribute as much as I want. Now that I am back in Canada I no longer have a test bench to practice with and I need some advice from seasoned programmers as to what Siemens components to use in a new test bench.
I need to learn how to:
1. Handle serial communications (EX: SICK Scanners).
2. Set up Ethernet (Ethernet to send information to servers which I.T uses)
3. Profibus – I would rather use profibus for input and output cards instead of I/O cards physically attached to the CPU (the company has lots of remote control panels and uses profibus extensively)
4. The CPU must be a 300 series
5 I have been using a CP5512 to communicate, but, once again I no longer have it. Is this the only method of communicating with the 300 series CPU? What do you recommend I order?
Can you please recommend the components to order so that I can build a test bench to cover the areas I mentioned (Communication cable, 300 CPU, Ethernet, Profibus)? please keep in mind that i want to get generic Siemens / Vipa components which are less expensive.
Thank you in advance.
Mike.
Depends on budget and what you have on site, you would want to match that and have a 'hot spare' set-up.
If possible I would get a 2DP version and not a compact if you only want remote IO (compacts are bricks with digital and analogue IO included).
For connection, Ethernet obviously as you will have that, also I now have a USB to MPI/Profibus adapter which is very good. Part No 6ES7972-0CB20-0XA0
But for the rest, chose from what your company has on site.
I'm currently working on a PLC setup and could use some advice on the best way to manage my power supply units (PSUs). Here's the configuration...
410
So, I'm about to start my first ever project that include a servo motor Here some of the component i bought for the project so far: - PLC: Omron...
388
Dear connoisseurs of antiquity and non-standard solutions, welcome) I don’t really hope, but suddenly someone had a deal and, most importantly...
582
Hey guys, We have a metal container at work, we fill with saw dust (20fts x 15fts x 10fts) with the top open but we normally put a container...
1,546
heya guys, For my project, i'm currently looking to add this type of linear encoder. The control company i'm working with told me they had bad...
1,215
