Solid Level Density Measurement sensor, need advice
Martindag
Sep 2009
quebec
227
Hey guys,
We have a metal container at work, we fill with saw dust (20fts x 15fts x 10fts)
with the top open but we normally put a container cover sheet over it to avoid the dust to fly around or the rain to get inside.
That container need to be picked up twice a week also.
I'm looking around if there was any level measuring sensors that could read the density of that container and ignore that cover sheet on the reading.
The sensor would be fixed on a structure outside and not the container itself to avoid removing it everytime its full.
I wish to use that measurement and add it to a PLC/HMI inside the factory for my operator to see that Level and do some alarm when its getting too full.
If you guys have any good suggestion, or anything else that would do the same job or even better, please let me know thanks !
I would think that any kind of optical sensor would have problems in a dusty environment. Can you just put a load cell under the container and start alerting at a certain weight?
Good Evening , I should know more about Solid State Relays . I have a system with 8) 120 vac Vibrators . These Solid State Relays have...
24
2,066
I have an Schneider M1E 171CBU98090 Processor adapter with only a solid red 'ERR' light lit. Manual explains flashing red ERR but not Solid with...
1,016
I am using an Allen Bradley CompactLogix 1769-L18ERM-BB1B to control an Allen Bradley 700-H series relay with a 24VDC coil (see pic) The relay is...
893
Hi to All, How I can change NPN to PNP solid state switch? Exapmle1: D-M9N Solid state switch with D-M9P Exapmle2: or allen bradley p.e.c. type...
1,440
Hello, I have a processor module that has a solid Red OK light. Status stuck on WAIT. I have tried the steps to clear memory/restore to...
1,494
