Need advice on how to use incremental encoders.
SilverLoop
Oct 2002
87
i have an application that has AB 845H incremental encoders connected to VFDs (Powerflex 70ECs). i can get the "raw encoder feedback data" to my plc program. i have a "home" proximity switch that is coming back to my plc. i am wondering how to deal with the fact that the drive will not have indication that home has been reached?
in other words, do i just stop the drive when i get the home prox input and then zero another variable that represents the encoder feedback? i need to have a consistent starting point in terms of encoder counts so that i will know how far a linear shaft has moved from home once the motor starts again.
thanks!
Yes, if inertion of system is small, this means that system stops immediatelly when prox is reached. If inertion is problem you must put two proxes. One will indicating parking mode of the system (variable=0), another one will serve as enable/disable increment for the variable.
I would have two speeds when you are referencing the drive slow speed until the prox is made then stop... if it is precise then 3 speeds, example:
Normal run speed @ 2500 rpm
Reference is needed speed CW at 800 until prox is made
If "Precise reference" is needed then CCW @ 300 until prox is not made
Now zero your counter
Just don’t forget the overtravel SW’s 🔨
When homing servos you can go to a prox then look for the marker (Z) channel of the encoder. This will be more accurate than a prox alone. In some cases I have disabled a limit switch and used it for a home. This may be overkill for what you are doing but it may give you some other ideas.
I'm currently working on a PLC setup and could use some advice on the best way to manage my power supply units (PSUs). Here's the configuration...
415
So, I'm about to start my first ever project that include a servo motor Here some of the component i bought for the project so far: - PLC: Omron...
390
Dear connoisseurs of antiquity and non-standard solutions, welcome) I don’t really hope, but suddenly someone had a deal and, most importantly...
584
Hey guys, We have a metal container at work, we fill with saw dust (20fts x 15fts x 10fts) with the top open but we normally put a container...
1,548
heya guys, For my project, i'm currently looking to add this type of linear encoder. The control company i'm working with told me they had bad...
1,217
