Need advice! Tapping into the market.
Benton
Oct 2010
Baton Rouge
34
Hi again guys,
I am an electrical ccntractor and I am trying to tap into the plc programming market. What advice would you give me to do this? I have done a small and limited project but that is about it.
What is the current mix of your business? PLCs are primarily used in manufacturing facilities. If you do mostly residential or commercial projects, you won't find too many PLC opportunities. Those that exist will probably be in the HVAC or "building automation" area.
If you're currently doing electrical contracting work in manufacturing facilities, you may be primarily dealing with the maintenance staff. If so, you may be limiting yourself to projects that simply replace existing automation equipment when it fails or needs to be modernized.
If you want to be considered for new projects, you should also develop relationships with the engineering, instrumentation, production, and environmental people. Ideas for which parts of a given facility to automate will come from all of those sources.
I'm currently working on a PLC setup and could use some advice on the best way to manage my power supply units (PSUs). Here's the configuration...
427
So, I'm about to start my first ever project that include a servo motor Here some of the component i bought for the project so far: - PLC: Omron...
398
Dear connoisseurs of antiquity and non-standard solutions, welcome) I don’t really hope, but suddenly someone had a deal and, most importantly...
594
Hey guys, We have a metal container at work, we fill with saw dust (20fts x 15fts x 10fts) with the top open but we normally put a container...
1,556
heya guys, For my project, i'm currently looking to add this type of linear encoder. The control company i'm working with told me they had bad...
1,244
