Need an Encoder
iadapt
May 2012
Indiana
177
I am taking a long shot here, but would anyone know where I can get gently used replacement encoder matching the one in the picture?
The lead time for a new replacement is killing me.
Thanks in advance.
this 2084 pulses per revolution encoder and may be 24 volt or 5 volt dc you can check encoder voltage and their are more brands like sick , baumer ,hiedenhien , faraba .....and so on
Apparently were using Grey Code, so I am not sure having never used Grey Code outside of school. Would this encoder send pulses like any other encoder or does it have a different count system unique to Grey Code. Would You know?
A grey code is an absolute encoder. It does not send pulses but an absolute number relative to 0-359 degrees of rotation. One turn goes from 0 to X where X is the resolution. Also grey code is not a binary output it only changes one bit at a time so the pulse output frequency is very low. Just google grey code and there are plenty of explanations for it.
heya guys, For my project, i'm currently looking to add this type of linear encoder. The control company i'm working with told me they had bad...
1,216
Hi, guys, how going? Could you give me a hand on my small project? One part of the project is that we want to use a shaft encoder (part number...
1,302
Dear all PLC's master, I'm trying to connect CPM1A to rotary encoder (Omron E6B2) using PRV with this code (0 0 DM100), but i can't read the...
6,158
I need to basically combine two modes. I need an instantaneous rate, which would typically use "Frequency" mode. However, I also need to know...
4,946
Hi Again, I have a pool wall line that I would like to update. It consists of a payout reel, corrugator, 2 punch presses, a shear, and a take-up...
3,489
