I need to basically combine two modes. I need an instantaneous rate, which would typically use "Frequency" mode. However, I also need to know direction of flow, which would typically use one of the two "Encoder" modes (I have two sensors offset by 90 degress). The problem is that the "Encoder" modes seem to only work as counters. I need them to work as instantenous rate. Can this be done?
We were able to do this using the SLC500 HSC module. We would set it up for encoder mode and it would give us a rate of either +/- a value. A value of 500 would indicate 500 gallons flowing in one direction. A value of -500 would would indicate 500 gallons flowing in the opposite direction.
When I set up the Controllogix HSC card in the exact same manner, it only gives me a counter instead of a rate.
HELP!
HELP!
