Need an inexpensive PLC and software for personal use
scada.plc
Supporting Member
Jan 2024
South Louisiana
I want to buy used/inexpensive (under $500) PLC hardware and software for personal use/testing. Can any of you suggest the best way to go about this? Brand doesn't really matter.
I recently had to work on a Micro 8xx telemetry master PLC (originally programmed by others) using Modbus RTU over serial radio modems and it was horrible. It was programmed relatively well, but the Modbus Message instruction and how it was set up is hot trash.
Sorry, but I was tempted to swap it with a Click except that would mean I would have to deal with the redundant iFix servers connected to it and that might actually be even worse.
I was required to use the software on the customer's computer and it crashed frequently and eventually got corrupted and had to be re-installed (Version 12 iirc).
Yeah, no thanks. Click Plus all day for me.
I would not recommend CCW software for my worst enemy.
Click or Click Plus with Ethernet would be my recommendation.
+1 to CCW - in short - trash.
My goto is productivity 1000 for small jobs w/o spec mfg, but Click Plus is probably best bang for your buck imo
Not to steal anything away from Mark, but as Scottryan03 pointed out, Automation Direct is probably exactly what the OP is looking for.
The factories on the last boat I was on ran entirely off Automation Direct PLCs.
I think my counterpart who was there years before me had stock in the company or something. They had AD drives and HMIs on everything.
AD was entirely functional and easy to use, but I am very happy to be back working with Allen Bradley again.
https://www.automationdirect.com/adc/home/home
Automation direct is good, there are also some cheap PLCs on ebay.
+1 for CCW being the worst.... (Actually, Proficy Machine Edition is the worst, CCW is second worse)
The guy asking the question probably doesn't know...
CCW = Connected Components Workbench, and it's the software used to program the Micro800 PLC mentioned in post #2.
Hi, My former company has 'downsized', and I've started my own business. I've been fortunate to have a number of friends who are helping out...
19
7,158
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
186
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
342
169
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
70
