Need Device Net Help
Maverick 250
Guest
M
I am being sent to another plant to help out. All their help left. They have a new huge assembly line that is in startup. It has problems with the Device Net addresses not all working properly. It is controlled by Control Logix. I am not an Allen Bradley trained person. I have not used or even seen Device Net or Control Logix. As close as I can tell, there is no documentation, no manuals, no support from the local distributor (hardware was bought out of state). There may be software on the laptop, maybe not. I don't know if control logix is PC based, plc, or ?
I am expected to go in, have a laying of the hands, and all will work. I am lost, and do not have a clue were to start. I am not even allowed to look in the door until the morning I am to report. I told them that this is utterly ridiculous. Their reply was "are you saying that you are declining your assigned work assignment". Does anyone need a clarification on what that means?
Thanks for any advice. There is no internet access allowed at that plant. Actually, not much IS allowed there.
M-250
Controllogix is a PLC, RSLogix 5000 is used to program them. RSNetworks is software used to setup a Devicnet network
You can goto www.ab.com and on the main page is a link to Manuals. Someone will have to provide RSLogix 5000 and RSNetworks software and hopefully a copy of the programming. If you havent worked with them before you have a large learning curve to go thru.
This is an RSLogix 5000 programming manual:
http://literature.rockwellautomation.com/idc/groups/literature/documents/pm/1756-pm001_-en-p.pdf
You can get info on devicenet at www.odva.org
Dear All I need A help On Following topic. i have one Allen Bradly micrologix 1200 PLC which is on Device net:hmmm: and at another side i have...
3,808
Hi All we are looking for a expertice people for develope new secuence in a robot ABB controlled and some I/O points configuration computer...
5,358
We are trying to poll data coming from a PLC for remote monitoring we have the IP address of the PLC and the default port number and the path is...
25
590
Does a hardwired 120 VAC machine need a local disconnect and lock out device? I was always under the impression that it did, but a plant controls...
2,100
Good afternoon to all, I have a machine that sends a 24 VDC signal out after cycle complete. This signal goes to the robot digitial I/O module...
2,054
