NEC question - Does a hardwired 120 VAC machine need a local LO Device?
theColonel26
Feb 2014
West Michigan
785
Does a hardwired 120 VAC machine need a local disconnect and lock out device? I was always under the impression that it did, but a plant controls engineer at a install I was on told me it didn't.
I was thinking that if it had a plug it did not, but hardwired yes.
Thoughts? References?
NEC Mostly but Also interested in UL as well.
NFPA 79 states that each “power supply circuit”, (does not specify voltage) have a disconnect within the enclosure or directly adjacent. Unless supplied by plug and socket, so my interpretation is yes you need a disconnect.
I'm mostly a controls guy, know a little about general wiring, but not a whole lot. Usually I always run each motor's leads in a separate conduit...
27
5,562
2,136
Hi I have a Sinec H1 card with both the run and stop lights currently illuminated. The CPU is in Run. Just got handed this and no idea what...
1,562
I have some reservations about a design I am working on. The customer has a fan motor that is mounted away from everything on a mezzanine. It...
1,599
There are many threads on this forum discussing the matter of using one circuit breaker for protection of several motors, servodrives of VFDs...
1,344
