Need devicenet backup crash course
The most common serious mistakes I see are:
1. Plug a device that's hard-set for the wrong baud rate into the network.
I'm assuming this would apply to connecting a 1776-KFD for communication as well. If so, how do I know what the baud rate for the network is prior to configuring the 1770-KFD to connect to the network with it.
Nevermind, I started reading the manual for the 1770-KFD and saw that it does autobaud.
I'm still trying to wrap my head around eds files and registering the EDS files on my laptop. If I have an unknown device and I need an eds file for it, can I change it in any way or screw it up by registering the eds file. Or, could it change the uploaded information from the device therefore leaving the .dnt file different from actual?
Good Morning , I'm finally getting through to upper management about the need to start eliminating our SLC 500 PLC's and Devicenet . I...
2,109
Hi all, First time I work with Devicenet and i've got the network up and running but I do not fully understand how the configuration works for...
2,215
Hi Everybody, I need your advice regarding pros and cons of using DeviceNet. We have an application with 17 VFDs and 33 fixed speed devices and...
5,118
The following is the pass down from 3rd shift, I have never dealt with DeviceNet, but maybe by the night shift tech's description maybe you can...
5,029
172
