Need help on LogixPro bottle sim.
Jonny Rev
Guest
J
I'm struggling to find a way to get the large bottles to fall onto the second conveyor,,, If somebody could help me get started. This electrician would be very greatful!!!
Use B3:5/4 bit. since B3:4 file length is 32 bit card and binary table is only 0-15 bits u have to use the next file B3:5/4 is the right bit target to open the solenoid
Yes, specially because the correct bits to use for the Large Bottle Diverter in Exercises 1 to 5 using BSLs are: XIC O:2/10 AND XIC I:1/6 AND XIC B3:5/5 AND XIO B3:7/3. For exercise 6 using BSRs, the bits should be: XIC O:2/10 AND XIC I:1/6 AND XIC B3:4/10 AND XIO B3:6/10.
O:2/10 = System Run Indicator (no Output should be able to energize if not in RUN mode)
I:1/6 = Encoder pulse "LS1 Exists'
B3:5/5 = Large Bottle sitting on the Diverter Gate
B3:7/3 = Broken Bottle bit at the Diverter Gate. If a broken bottle was previously ejected, leaving a space, then the Diverter should not be energized (causing unnecessary wear).
I'm using loxixpro. My problem: I enter an RTO but cannot put an address to it. I have tried every way I can think of.
1,725
Greetings, I have been using LogixPro program and i am really bad with it..:bawling: I am working on Bottle Line and got lots of problems.. i...
1,815
54
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
348
174
