My boss is pretty mutch letting me pick what i want as long as i don't spend to mutch money. Main thing i will be running S7, Win CC flex And starter. Wonder what operating system they will like best?
Have you had a look at the Field PG? Pricing is actually reasonable if you take into account an upgrade of all your siemens software and transfering the license over.
http://www.automation.siemens.com/simatic/programmiergeraete/html_76/produkte/varianten.htm
I have the previous (Premium)version. Very very well built, and not had any trouble with it in 3 years!
It has a real serial port, and it will use the cheaper PG
version of the S5 cable, plus built in MPI port.
We use ours on S5, S7, AB SLC500/Micrologix, Mitsubishi, Omron etc. The machine is loaded wit PLC software etc, and all runs ok
The SIMATIC Field PG M2 is available in two versions:
PREMIUM
2.2 GHz Intel Core 2 Duo processorMulti-standard DVD RW15" SXGA+ display (1400x1050)200 GB S-ATA hard disk1x 2 GB DDR2 RAM (2x 2 GB max.)
Just dont tell the boss that there are two versions
ie just spec the premium unit!
The SIMATIC software is ready installed on the Field PG M2 and can be enabled by means of a license key:
Trial License
- STEP 7 Professional
- WinCC flexible AdvancedEach Field PG M2 comes with a license that is limited to 14 days.
Upgrade License
- STEP 5
- WinCC flexible AdvancedContinued use of existing software licenses following replacement of "old" PG hardware.
Powerpack License
Upgrade License
- STEP 5
- WinCC flexible AdvancedUsers who use SIMATIC S5, SIMATIC S7 and SIMATIC HMI and who wish to upgrade from STEP 7 to STEP 7 Professional.
Floating License
- STEP 5
- STEP 7-Micro/WIN
- incl. EPROM adapter and
- S5 PLC cable Users who use SIMATIC S5, SIMATIC S7, engineering tools and SIMATIC HMI.
