Need Help on STEP 7-Micro/WIN
muhd amru
Jan 2011
malaysia
Good day to all~
I'm new to the world of plc and programming hope u guys could assists. thanx.
I'm using STEP-Micro/WIN V4.0.8.06 with modbus library installed to program S7-200 CPU226.
my question is how do u mapped the input or output to the modbus address?
i've read all the manual and help file on how to use the modbus library instruction but cant really understand it.
i know that 10001-10128 are discrete inputs mapped to I0.0-I15.7
are they mapped by default?
can i mapped I0.0 to 10021 instead of 10001?
if i program I0.0 to set output coil V0.0 to 1, then how can i map V0.0 to modbus address 100021 for example?
i know this all are like silly question for u guys.. but can anyone help me with it? Thank you so much for your time and consideration.
Thanks and regards,
Amru
ok how about this? i've tried to construct the same program as the example in the manual but with my own modbus address and holding register add; the result, instead of MB1 = 0, i've got MB1 = 5,
what does it mean by MB1 = 5? i tried searching for the error code but can find it.. could someone please help me? is there any table for the error msg? thanks.
owh.. found it already bout the error code.. u can find it in the help files.. ><" under Modbus Master MBUS_MSG Execution Error Codes..
and for the rest im still trying.. thanx a lot guys~
u've been helpful.. =,="
Hi all, I'm using Siemens S7200 PLC and I want to connect it on a motor using a step driver, but im having a hard time on how to...
1,546
I need to build a ladder diagram for the following circuit: Can some one help me please?I have downloaded STep 7 lite and reading pdfs about...
7,763
hi, help me please, how i make of procedure for instalation del disk yellow automatic licence key disk, i have the data lic-no khe: id, but in...
2,263
I have started working with siemens step 7. The program I am using is in ladder lodgic. The problem is there are no descriptions with the program...
2,807
I need to make communication between a equipment that uses profibus and S5. How can i do it? banghead Anyboody could help me?? thank you all
2,748
Unregistered
U
