Need help opening an .RSP File
.RSP File to PDF
Hi Everyone,
I have a similar problem. There is an sample ladder logic program I'd like to check out for the Prosoft Modbus TCP/IP converter. Could someone please help to convert to PDF?
The help is much appreciated! Thank you! 🍺
Yet another person with a request for RSP conversion
Hey all, can someone please convert this RSP file to a pdf so I can actually look at it? I've got RSLogix 500 and 5000 on hand but, alas, no 5.
Thanks.
-Phillip
you should have it - but sometimes a company filter will keep it out at your end of the pipe ...
let me know if it comes through ok ...
good luck with your project ...
RSLOGIX5 5/30 Program Issue
Ok We own version 4.10 and I did find version 5 on one of our other computers. I have a client who gave me a PLC program to evaluate for a Controllogix rewrite. So when I used version 4.10 and opened the file it said something along the lines that a newer version was available would you like to use the autosaved version. After saying yes I looked at the program and found some issues with the BTW and BTR instructions, I figured maybe these were anomalies so I closed the program and opened it again, this time I replied no i don't want to use the auto saved version. The RSLOGIX Interface shutdown. (I always work with a backup, so I went back and used an unused version and the autosaved version opened like normal and once I reverted back to the unsaved version the interface shutdown. This occurred in version 5 as well. I think the program was saved in later version and when i don't use the autosaved version (newer) then the program takes a dump. Anyone else know about this ?? HELP
Hi, I'm currently completing a PLC lab for one of my courses and the report needs a pdf version of the ladder logic. Unfortunately I don't have...
1,346
Help and Hello, I got a PLC program sent to me with three files. The extensions are DMF, LAB and PRG. The program is for a Omron C200H PLC. I...
3,323
i was given a directory folder with the following subdirectories: Cache Comprf DLGLOG EDS Gfx Global Objects Images KEY LNG Local Mcr PAR RCP...
5,969
50
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
347
