Need Help :problem in RSlinx driver
Oct 2010
I have using 1747 AIC.It is connect with SLC 5/03 and Panel View...
But when i connect RSlinx driver,some error occurs..
Any can give the solution
Error:"Swap driver Failed() to swap the new pic driver ,try restart rslinx"
"Failed to swap windows 2000 PIC driver.see the application event log specific error
Win error code:3758096907"
See u need to check up with the commn.settings in the program u have uploaded.also check the 6 pin cables used for aic module.their b aud rates b/w hmi and plc should be same and also check for node no: Is properly configured
Post a comms config screen shot
You probably have some other driver assigned to the com port your using (comm1) and thats why it wont swop
What driver are you using?
If its the 1747-PIC/AIC+ driver you will need a real serial port, do you have one?
Can you give us the complete catalog number of your Panelview?
How is the panelview connected to the SLC5/03 ( its serial port or DH485 port)?
This is the problem, I need to solve it using a ladder diagram: Write a table of inputs and outputs and propose a control solution for a screw...
22
3,985
Public WithEvents oGroup1 As TagGroup Public vidrios1, vidrios2, vidrios3, vidrios4, vidrios5, vidrios6, vidrios7, vidrios8, vidrios9 As String...
2,706
Alright guys im fairly new to the plc world but here is what I got one of our RIO 1747 ASB has been down for service now we are ready to power it...
2,641
This Problem happened many times, is it only because the wrong type DB10Q0 should be DB1010 or any other possible cause? HMI log file ...
8,571
Guys, I have this remote rack communicating with a SLC 5/04. There are several "Analog" output cards in this RIO that are being used to control...
2,620
