Need help regarding 1756-dhrio Massaging
souviknaskar
Apr 2010
kolkata
21
Dear Sir,
I am never work on DHRIO network please help me how will be the massaging for attached configure network.
Thanking you.
Regards ,
souvik
Can you be more specific about your question ?
The 1756-DHRIO will be in RIO Scanner mode, and will communicate the I/O data from its attached networks to the ControlLogix over EtherNet/IP.
This is a normal network architecture to connect a small number of Remote I/O devices to a ControlLogix Redundancy controller.
The amount of I/O data and what parameters in the AC drives are represented by that I/O data can vary; it can be as simple as Command+Reference / Status + Feedback, or multiple parameters can be read and written from the drive using a feature called "DataLinks".
Is this a system that you are implementing, or one that you are troubleshooting ?
Is there a good reason that the RIO network was maintained instead of migrating those AC drives to use 1203-EN1 network interfaces directly to the EtherNet/IP network ?
Dear Memners, i have an issue regarding factory talk view alarm sound, i have set internal bell for sevarity =1, internal speeker are working fine...
2,141
I can’t able to get data from IN16I analog card, signal type 4-20 ma System configuration Rack 1 Slot-0, L551 CPU Slot-1, BSN Rack 2...
2,079
Ok I was not sure where I could post this or if there is any answers on this site. But I hope someone can help. I have an older Burnham B3...
2,679
Dear Guys I need help regarding PLC. I am stuck for some days now and problem is strange. Machine PLC has two encoder modules when machine is...
3,037
hi guys. currently doing my project regarding PD in PLC. My PLC is panasonic FP-X C30R. I need to know how am i suppose to have a PD controller in...
2,003
