need help, servo or VFD?
Thank you, jraef !
This is what I was searching for! You give me and all members a detail description of this topic. Thank you again.
As for your suggestion PW755, I'm afraid that I can't use it cause our power system is 220v 3phase ac power. I checked the spec it only support at least 380v .... do you have any suggestion?
Hello,
We are going to upgrade an old bandsaw so that we can feed the wood automatically. The requirement is easy -> can control its speed and there is a button to let it go back. I planed to use Powerflex525 or Powerflex70 to do the job but my boss prefer servo. What's the suggestion?
I'm new to this area but I had spent must time to research in the network. From what I had learned, I think I can use an FOC VFD and induction motor to do the job easily cause we only concern speed and torque(all speed range). Does this kind of VFD (with encoder) can provide stable speed control like a servo? If cost is not an issue, which one is better to provide a stable adjustable feedrate in this case? Thanks for your help :)
I thought "VFD" when I saw "...can control speed..", since that almost always means "velocity". And, I seconded myself when you said "..my boss.." and "..servo.." in the same sentence. Servo applies when you are matching POSITION to something else, or need to maintain POSITION with great precision...(among other things), and, by the way, its more than the drive...you need a special motor, motor mount, oh-yeah, motor cables and such.
The torque and speed requirements near 0.00 velocity would be the only thing that would move me away from a VFD (i.e. a traditional VFD), but, even then, I'd be looking at a Movi* drive from SEW if I needed something exotic.
Just my 0.02
Sorry for making you confused, English is not my native language please forgive me :(
If you had noticed someting wrong, please let me know :)
Btw, I can't edit original post anymore :(
I'd use a good sensorless vector drive like ABB or the higher performance AB drives. It'll do the job of feeding the stock just fine without the expense and maintenance of an encoder. More than that is really overspecifying unless I've somehow not understood the application.
Hello automation experts, I'm trying to learn about servo axis control in AB ControlLogix PLCs (L33ERMS). Attached is an example of a servo...
1,077
Hi everybody I am using a servo which model is MR-J3-10B (GA). Now I have an alarm code 96(home position setting warning). How can i fix it?Please...
1,573
Hi everyone, I'm having problems with simatic s7-300 & sinamics s120 system. Some error code are being appeared,Now how can I fix these error. I...
1,497
What does mean by the following instructions? DP.SFCS H3E1 K1 DP.SFCS H3E1 K2 DP.SFCS H3E1 K3 DP.SFCS H3E1 K4 DP.SFCS H3E1 K10 DP.SFCS H3E1 K20...
1,846
Hi everyone, What should I do if I got this error? 31885: Encoder 1 DRIVE-CLiQ (CU): Cyclic data transfer error (Component number: 17, fault...
6,667
