need help to communicate S7-300
raul_vaze
Feb 2008
mumbai
87
I have S7-300(CPU313C) system . I am able to connect to the CPU through the MPI adapter. However when i try to download the program then it doesnt let me do so .and tells me "The system with which you are online with differs from system which was configured offline.Download is not possible"although everything is ok and processor is properly selected.When i try to upload it doesnt let me see the CPU information and says it is write protected.I also tried with MRES but nothing has been solved.
Programming software is Step7-Lite(3.0)
MPI adapter address is : 2
Plsss help
Not sure, but I think your offline HW Config doesnt match the actual PLC hardware.
Hi JesperMP ,
thanks for your reply but i feel my firmare version of programming software is not matching with firmware version of CPU. I tried with Simatic manager v 5.3 and it has CPU313C with version 2.0 while my hardware is CPU313C with version 2.0.12 . Do u have any idea how to upgrade firmware of the programming software .
Hi Jeser Mp ,
Have u ever worked on FB58 which is auto tune PID controller . I am trying to configure but i am unable to do it as there is no information to start the auto tune . I have called the same FB58(Instance DB is created) in OB35 . Please help me in configuration
Title summarizes the overview of the problem. I am trying to make AVEVA Edge 2020 and a Schneider TM241CE40R to talk to each other via Modbus...
18
2,108
Dear friends, I need help, please. I use a PLC "micro850" which will read the data of an energy analyzer "Sentron PAC3200" via a Modbus TCP /...
2,808
im trying to connect a fx-1n PLC with hyperterminal using USB-SC09 (rs-232<->rs-422 adaptor). im using computer link with a dedicated protocol...
3,193
Dear Friends, We have a setting machine in which 20 Parker Servo Drives and motors (name plate images attached) used to place the tools at...
3,888
61
