mrchris76
Hello all,
I am working on a tracking system, using RSLogix5000, for my factory that will allow me to transfer data for each product load at each step of my process. The data will be displayed using Wonderware. The total process takes place on a system that is the length of 1.5 football fields so the guys at one end are not privy to what is happening at the other. Most of the programming has not been too hard since there are points in the process where the product stops and the next load will not transfer until the previous load has moved on. I used these stops, triggered by photoeyes, as the conditions for transferring data to the next step in the process. My problem is that the in the middle of the process is a section where the product moves at a constant speed until the end of the section. This section is 144 feet and there can be up to 20 loads in this section at any given time. The section is broken into 9 sections and there is one photoeye per section but the product does not stop moving once it enters.
- I tried using the photoeyes to transfer the data like I did on the rest of the system. This did not work since multiple photoeyes would be covered at the same time. This causes the system to propagate the data in section 1 all the through to section 9 at times.
- I tried using timers to time the loads through each section and transfer the data when the timers were done. Again I ran into the problem of having multiple items triggering at the same time. If I only had one load going through it works but I couldn’t figure out how to make it work using multiple loads.
- I tried using FFL function but the number of loads in the section varies and there are gaps in the process at times that need to be accounted for.
I am hoping one of you guys can point me in the right direction because I am at a loss as to how to make this work.
Thanks in advance.
Thanks in advance.
