Need help Uploading a program to a SLC500
Stealthultra
Oct 2020
Texas
Hello im hoping someone can point me in the right direction. I have a SLC-500 that the program has been erased. I'm being told it will require an engineer to come out and install the program. This will cost appox. $4000.00! Seems high to me. Is there a way i can connect a computer and install the program myself?
Thanks in advance for your help!
Do you have a back up copy of the PLC program? If so, then you should be able to find a local company that will load the PLC for you at a reasonable price.
If you do not have the backup, then $4000 sounds cheap. Someone is going to have to recreate if for you.
If you have a backup then 4000 is expensive, however, I'm surprised at that cost and it's not the sort of thing I would do, I prefer to do it on an hourly basis which includes travel expenses, hours worked etc. some companies do not like an open contract but you have to look at a number of scenarios.
The company/person does not know what the issues will be until a visit to site for example, has the PLC just lost it's program because of a flat battery, is it a fault with the hardware (very common on SLC like processor, rack, PSU).
Is the backup you have readable, is it the correct one and up to date. so many issues. I would shop around for a better deal. You will need the software for SLC (RS Logix 500), a cable which depends on the processor, it could be 232, 485 or ethernet some have more than one port. that version may not work well or at all on Win10 PC, also it will depend on what version of software used to create it (cannot remember what the old dos version was, believe it was APS).
I have a PanelView 600 and am trying to upload to a laptop running PanelBuilder32 Ver. 03.80.00 and RSLinx 2.42.00 A serial null modem cable...
5,020
30
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
342
169
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
72
