Need Help With Ab Guardlogix
pat@magnum
Aug 2007
Jerseyville, IL
Having dificulty making heads or tails of the software. My background goes back to the days of the Omron S6 PLC's. I have experience programming most brands of PLC's with most of my experience with AB and GE - but I'm just lost with this stuff. Even their ControlLogix was straight forward compaired to the GuardLogix. I only need to check a couple inputs, if valid enable an output. Another input will reset for recheck - sounds simple ......
GuardLogix uses RSLogix 5000, just like normal ControlLogix. Configuration of the safety I/O and the safety task is a little more complex, but the instruction set and the editor are very similar to the standard product.
Rockwell has a handful of non-Logix safety controllers and they are, I agree, a lot different. RSLogix Guard Plus software for the GuardPLC, and the editor built into RSNetworx for the SmartGuard 600 controller have a totally different learning curve.
Which exact product are you using ?
GuardLogix 1200.
Was suppose to come with "light" version of the software, but was apparently discontinued. I know when I worked with ControlLogix platform I had Ladder functions on the toolbar. ContolLogix did not seem that foriegn to me, had my ladder environment - only real difference seemed to be data addressing as I recall.
I do think you need version 14. Because the RS Logix 5000 Software went
from Ver. 13 to Ver. 15. I would also make sure your RS Linx is updated.
We had a problem with it crashing ,until we did those updates.That was
about a year ago.
Let's be specific.
You have a GuardPLC, not a GuardLogix. RSLogix Guard Plus does look and work very differently from the RSLogix 5000 environment that most Rockwell users are accustomed to.
I have only worked with GuardPLC and RSLogix Guard Plus in lab environments, so I probably couldn't turn around and teach a class on it.
Your first step ought to be seeking out documentation. Do you have any collateral other than the software CD ?
If you search the RA Literature site with the keywords "GuardPLC 1200 System" you get about 10 hits including the Programming Manual.
54
348
174
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
77
