Ok This is what i got its a bin filler that goes from left to right. when LS2 is made and Prox1 is made i want it to go left and when prox3 is made stop. But it keeps coming back right and then go left . Really confused.
][ estop------][H/A------][LS2------][Prox1----]/[o/1-----]/[Prox3---()o2 Motor Left
And i got H/A branched with a manual switch on this rung.
][estop-------][H/A------][LS1-----][Prox2----]/[o/2-----]/[Prox4---()01 Motor Right
I may be way off here but..
It would appear that you have the two bins present at the same time? so before start the conditions to run motor right and left are made?
The code then prioritises the first output it scans (02 MOTOR LEFT)locking the other output with the N/C (01 MOTOR RIGHT).
Unfortunately when the motor reaches position the prox switche (PROX 3)turns the output (02 MOTOR LEFT) off releasing the other output(01 MOTOR RIGHT). to go on.
This will cause the left to right movement forever
consider this
I assume
LS2 BIN LEFT PRESENT
PROX 3 MOTOR LEFT
PROX 1 BIN LEFT EMPTY
LS1 BIN RIGHT PRESENT
PROX 4 MOTOR RIGHT
PROX 2 BIN EMPTY
][ estop------][H/A------][LS2------][Prox1----]/[Inseq Right-----]/[Prox3---(SET BIT)|Inseq left
][Inseq left--]\[Prox3--()o2 Motor Left
][LS2--][Prox3--]\[Prox1--(RST BIT)Inseq Left
][estop-------][H/A------][LS1-----][Prox2----]/[Inseq Left-----]/[Prox4---()01 Motor Right
][Inseq right--]\[Prox4--()o2 Motor Right
][LS1--][Prox4--]\[Prox2--(RST BIT)Inseq Left
